Relaxing while cleaning locomotive wheels until.........
you see a worm bearing fly out from under the body one way & the truck try to go the opposite direction.
After a few choice words, remove the coupler boxes, remove the body, return the part that tried to get away back on top of the truck, put it all back together & relaxation commences again.
The culprit is the loco on the right, pic was taken years ago on the old layout @ the old house.
You are fortunate that your little piece did not take a trip down an air duct or get batted into some inaccessable spot by a pouncing feline.
Have fun,
Richard
If not a cat, how about a dog who thinks that flying morsel must taste wonderful, and it’s gone in an instant. SLURP!!!
Or fall into the time/space warp that is about an inch off the floor… Blink!
Those always turn up in the end…if you look carefully :wink:
It looks like you’re describing an Athearn SD40. I’ve taken a few of those apart and put them back together. The Life-Like S-3 (coupled to the gondola) can be tricky to take apart too.
