I introduced my remotored Gem Models HOn3 New berlin & Winfield 2-6-9 in this weeks Weekend Photo Fun, but I wanted to treat the conversion a little more in-depth since I took quite a few pics along the way. I’ll start with a recent video taken once what I now cakl Silverton RR #7 got it’s chip and paint, but before I added wipers to improve performance,
With some research, you can find older brass locos, particualrly tender-drive ones, at fairly reasonable price nowadays. While the price reflects the fact that they don’t have all the modern features many consumers now expect, these types of loco models are pretty easy conversions and DCC is easy to update them with. Sound can be more of a challenge, largely because of the limited space available in a tender-drive loco. This little Mogul may yet get sound, but for know it’s just gear noise.
Here’s what you’ll have once the tender frame is stripped down.
The L-shaped upright bracket formerly held the 5-pole old school motor that originally powered this loco. I left it in place, because it was useful for me. It’s just soldered on, so can be removed if that works better for you.
Next step was build a frame to hold the motor. Mine is shaped like a capital I with the top and bottom resting on the tender truck bolsters.
Some folks keep it simple and just use a spot of RTV to hold a motor in place. I considered doing that, but found I could use a piece of phosphor bronze sheet bent to form a U-shaped motor holder that made it easily removable.
The small bit of brass towards the left/back bottom of the circular motor mount is designed to tilt the motor and driveshaft downward towards the front of the loco. This tends to align it with the downward-sloping drive gear that the tender drive engages.
I picked up this tip and a lot of other useful info from the late Boone Morrision, who I had the pleasure of meeting in person over dinner with others from the old HOn3 Yahoo group at the 1998 (IIRC) Colorado Springs National Narrow Gauge Convention. His series “Route to the Redwoods: The HOn3 North Coast Narrow Gauge Line and Its Subsidiary, the Buckhorn Logging Co.” [now that’s a title and a half!] ran in the Narrow Gauge and Short Line Gazette begining in 1997 for a number of years. Specifically, he begins discussing such tender drive conversions starting in the Sept./Oct 1998 issue and continued the discussion in Part 11 in the next issue. He relied on old Far East Distibutors 4-4-0s for the majority of his motive power needs.
Eventually, Boone discussed how he changed from using the typical silicone tubing flex drive to the loco over to using a much more discrete spring wire for this driveshaft. This may have been discussed in the HOn3 group, rather than in a published article, as I haven’t located that info yet. For now, I simply replaced the existing silicone with new after I created an adapter to enlarge the motor drivehsaft from a couple of piec
I want to comment on my soldering. There’s some sketchy stuff in various places. It will all be hidden, so not too concerned. I did a good job on the farme I added, but just couldn’t get it soldered to the front bolster like I planned. The other end was held with epoxy because you couldn’t reach it with the solder tip. I eneded up epoxying the front end, too. The main thing you want to avoid is spontaneous disassembly, which can happen if you get things hot enough in the right places. Just remember that epoxy won’t provide you an electrical connection if that is needed.
Next was a test fit for the motor and flywheel. Testing fitting is good guidance, so do it as frequently as possible.
Then I cut a big hole in the top of the tender - Yikes! [:O]
After lots more cuttings filing and smoothing, the sheel fit well without intefering with the flywheel.
Here’s a view of the front of the tender. The general idea is to get the driveshaft centered.
After I got everything together, it was time for some DC testing. I got out my Blackstone ProTraxx HOn3 test loop (think Kato track in HOn3, b/c that’s exactly what it is), which is where this video came from in WPF.
It ran prerrty well because of previous finetuning, but I did my best to get it running well on DC. Next up, the decoder, shown here with the wiring ready to get stuffed.
I decided on a Soundtraxx DCC Mobile Decoder. It has a lot of the drive control features found found on Soundtraxx sound decoders, but in a very compact and economical package. This one is a Model MC1Z102SQ.
I cocooned the yellow wire in case it was every needed for a backuop light, with the decoder and much of the wiring being stuffable in the rear of the tender.
While we’re on the topic of parts, here is a link to the Locodoc Mashima motor page:
Mashima was one of the companies affected several years back by a cutoff of export of certain rare earth resources by China, which were used in making the magnets Mashima used. Locodoc stocked up on these motors and can also supply custom flywheels to suit your application, as well as offer sage advice on improving loco performance. The flywheels just slides onto a friction fit on the driveshaf
Since this is HOn3, could you help me with my sense of proportion by laying a quarter or something of recognizable size near the tender to compare to? I’m having a little trouble getting a real fix on the size of things here. My eyes want to make the trucks HO standard gauge. Dan
Yeah, not much sound on that one video. Here’s one I posted in WPF that I spend lots of time commenting on the loco’s size that also addresses Dan’s question of how big to a certain extent.
I sort of express doubt that #7 will be able to handle to handle the 2-car train that sits behind #3 in the video. But testing this morning proved #7 can handle that passenger train up the 4% leaving Tefft on the Cascade Branch. There’s a few spots where the track needs a little worrk, mainly a few dips that the longer driver wheelbase C-19s just run right through, while the six-coupled #7 tends to drop in that hole. However, careful attention to wheel slip gets you up the grade.
I’m having issues with pics in this thread. I couldn’t get the one to post yesterday and now I see that other pics have actually disappeared from the thread…very strange. Will deal with it later so patience for a little while before I can get back to this later today.
Yeah, even newer motors would have a hard time fitting in that tiny boiler.
Boone passed away a year or so ago, IIRC. His wisdom is certainly missed. He wrote a few articles for MR, too, in addition to the Gazette. He’d switched to On3, then got busy and not much heard from him, but his illness likely accounted for that. The fellow had class, was willing to share, and was down to earth. RIP, Boone.
Ulrich, Thanks for your comments, too. This is strictly 1960s tech until the can motor and decoder are stired in, so it’s something I’m sure you would enjoy.
Pics seem to have come back, I think. Here’s a couple more in the "How small is it really? " category, a side by side compariosn to a relatively small loco, a K-27.
And since it looks like pics may still be futile, I’ll try the F250 comparison again…
Ulrich, Nice loco and she runs well, just not very far.
I’ll try a couple of more size comparison pics comparing it to the K-27:
Darn, very strange. All the complaints about posting pics lately seem to indicate that it’s changes at the phioto server end that’s the cause. I’m unaware of any changes at my host (photobucket) and my pics post just fine elsewhere. This makes me wonder if it’s something at the Kalmbach end of things that has changed? It’s also intermittent, as my pics have disappeared and returned several times since I started this thread. The ones that I was able to post are now back again, but current posting isn’t working, again. Videos seem unaffected, though. Very strange, indeed.
Well, pics are back right now…keep your fingers crossed.
Not really saying it’s MR, either, just that there seemed to be some correlation. Our ISP is also having DNS issues lately. I get half the internet and no email sometimes, so there are lots of potential fault points in making pics work,
