I’ve been working on a Bowser/Cary H16-44, (see http://cs.trains.com/mrr/f/13/t/282489.aspx) which uses an Athearn F7 frame. I had an Athearn F7 dummy and a damaged Proto 1000 C-Liner, so I thought I would use the trucks and motor for this project. I had some spare Proto 1000 F3 Driveshafts, which seemed to be the right length.
I found an old thread, http://cs.trains.com/mrr/f/88/t/208603.aspx , with some pictures of an Athearn remotoring by Jeffrey Wimberly. It looks like he just held the motor down with RTV silicone.
I need to mount the motor vertically, though, so I made a simple mount with styrene, and held it in place with a ziptie:
The motor is sitting on the frame in front, so it’s not quite level. It seems to run ok, but it’s a little noisier, probably because the motor is right on the frame. I’m thinking of grinding out the frame a bit so the motor is level, putting some silicone down, and sticking the motor in. This would eliminate the ziptie and cushion the motor a bit. Or I could leave well enough alone…
Should the motor and driveshafts all be aligned? If so, any problems with my plan?
EDIT: Can’t get links to display correctly. Giving up.
