Ok, so this probably isn’t worth it’s own thread, but I don’t see another spot to put it and it’s a handy tip, so here it is.
I had been puzzling and pondering how to get the ore loads out of my gondolas without plucking the entire car off the track, inverting it, and dumping the load back into my hand, then having to re-rail the car and reassemble the train every time.
I thought of buying some shovels, cutting off the digging blade, drilling a small hole in the pile and gluing the shovel handle into the hole to give me something to pick the load up with, also thought about a tiny wire sticking up just enough to get a fingerhold on.
Instead a much simpler solution cropped up, and now that I’ve tried it, I found it works great and uses no visible “handle” to pick up the load.
I use luan plywood (1/4 inch thick) as a base for my loads, followed by the usual ballast/alcohol/2 parts water to 1 part glue, and this time around, before painting them, I hauled out the belt sander and cut a slope into the bottom of each end of the plywood, 3/16th inch deep and half an inch long.
Now whenever I need a car to be empty, I just push down lightly on either ned, the far end pops up like the far end of a seesaw and I can then lift it out of the car without disturbing a train.
I’m sure somebody thought of this a log time ago, but since I hadn’t stumbled across it, a repeat seemed like a useful idea. It only works on flat bottomed cars like gondolas, but since that’s what I’m using, it’s all I need.
While on the topic, I tried painting the loads with spray paint and was less than satisfied with the results. You could tell what it was supposed to be, but no real sparkle of realism. After some experimentation, the results I like best use layered paint. I start with the darkest color I want “in the pile” and hit the load hard with that, covering every nook and cranny. Then I go over it using a nearly dry brush, adding a glossy coat to coal load
