Remove acrylic paint from clear plastic model window?
I’m squinting to repaint an Atlas N scale caboose in more realistic colors, and didn’t notice some acrylic paint that I got on the small clear plastic windows.
  1. What’s the best way to remove, cover, or hide paint stains on the clear plastic windows?
  2. Would a liquid masking product be my best bet for the tiny windows in the future?
    Thanks!
    -Doug
You should be able to remove it with tooth paste. If it is really thick, scrap most of it off withh a razor blade then put some tooth paste ( Crest works well ) on a soft damp rag and rub until it’s off. The tooth paste will poli***he the plastic and not leave any scratches.
91% alcohol and a pencil tip eraser or q-tip should do the trick…
Since you didn’t notice, maybe no one else will either! [}:)]
Great suggestion on the toothpaste!
It’s funny, we often talk on this forum about using toothpaste (Pearl Drops) to poli***he gears inside of Athearn trucks. This is the first time I’ve ever seen it suggested to polish clear plastic.
Thanks for the tip!
