removing decals
Is there any way to get the decals off a athearn genisis sw 1500 with out hurting the paint?
Not sure if this is the same or not but I just removed some Penn Central logos off an Athearn Genesis F7. I used Microscale Micro-Sol to soak the area I wanted to remove for about 5 minutes. Then I use a pencil eraser and it came right off a left the under paint in good shape. I did not erase for to long just enough to remove the logo and tried to concentrate in the area to be removed. I hope this helps.
If you dont have any Micro-Sol around, you might want to try Rubbing alcohol and a pink eraser. Try and get the 91% alcohol. Kevin
