Removing dried acrylic paint from spray jars.
Picked up some discarded badger spray bottles with dried acrylic paint inside. Tried soaking them in 91% alcohol for a week with not any success. Filled them with water & dishwashing soap . put them in a larger container with more water & microwaved them for 3 min. (depends on the size of your containers). Removed them when still warm & the paint came right out. Now have 5 more clean spray bottles.
I just use lacquer thinner - They clean up real fast.
Jim
I did try the lacquer thinner with no success. It does work on solvent based paint. I think this stuff was in there for years. Ammonia works if it is fairly fresh.
Thanks for the tip! Dried acrylic paint can be amazingly resilient.
I’ll try the microwave method next time. Hope that your previous efforts weren’t necessary for this to work.
Kyle
If they are glass jars, you should be able to use paint stripper.
I only tried the alcohol & the thinner on one jar. The other 4 went directly in the microwave. This is also the least toxic & least expensive method.
