The particular boxcars I need for a project aren’t available in undecorated, so I was forced to buy decorated ones … question is, what is the best method to remove the lettering from these cars to get down to a smooth paintable surface.
If at all possible, I’d like to retain the base color, just remove the lettering. Anyone have any success in doing this ?
I tried several methods to remove lettering from some Proto1000 Fowler Patent boxcars, including methyl hydrate, brake fluid, and PollyScale E-Z Lift-Off, none of which worked. I ended-up using a #17 chisel blade in my X-Acto, dragging it with the non-bevelled edge leading and the handle leaning slightly in the direction of travel. The lettering was removed and the paint, for the most part, was undamaged, although I repainted the entire cars as I had replaced all of the steps and grabirons with metal parts:
