What is the easiest technique for removing grab irons that are molded on? I have some locomotives that I want to remove the molded on irons and replace with actual grab irons.
Micro Mark sells a scalpel w/ interchangeable blades. I use the chisel blade & shave them off VERY slowly. Take a little at a time. If you are careful you can save the bolt detail & that will give you the correct location for the new grabs. Drill the mounting hole w/ a drill in a pin vise 1 size larger than the diameter of the grab. Use a pc. of styrene under them to keep them the proper distance from the body & secure them from the inside W/ a drop of CA.
XACTO also has a chisel blade, but it is too wide for my liking. Jerry
Single edge razor blade. I have a full assortment of hobby knives/blades as well as surgical scalpels, and the razor blades are still my most used hobby tool.
I agree with Dave, the Micromark chisel works well and the handle with ridges lessens the probability of slipping and chiseling your fingers. [banghead]
