Removing paint from locomotives
Hoe do I remove acrylic paint of my athearn locomotive. It looks really bad right now. Please help
ShaunCN
Try the search function of the forum, we already had this topic a few times. i use 96% isopropil alcohol, which you can buy in most pharmicies. put the shell in it for a few hours and bru***he paint away with an old toothbrush.
Micha
If your paint was a water based paint, then soaking it in warm soapy water might help. Give it a while and see.
If your paint is an oil based painted, (oh no) you will need something like paint thinner to help you.
I hope this helps.
On most newer shells you should only use alcahol
I tried hot soapy water and it removed the paint
Thank you
ShaunCN
Pinesol
