I recently bought an original run PCM / BLI I-1sa off of Ebay. It ran fine initially and then stopped. I took the bottom cover off and quickly realized the main gear was cracked. Apparently this is a common problem but I wasnt aware of it when I made the purchase. I contacted BLI and they will replace the gear on the driver free of charge. Unfortunately, I can’t figure out how to remove the driver from the rest of the running gear. The other drivers appear to have bolts connecting the siderods to the wheels, but the main driver seems to have a rounded pin. If anyone could provide some guidance it would be much appreciated.
Thanks
Nathan
