Has anyone renumbered any of the Broadway AC600CW’s? I have two of the SP’s and both have #600 so I want to renumber one of them and was wondering what the best technique is to remove the “600” below the windows and on the back.
Regards,
Rod
Regards,
Rod
I HAD GOOD LUCK USING 3M AUTOMOTIVE SCRATCH REMOVER ON A Q-TIP. IT IS TECHNIQUE SENSITIVE SO RUB GENTLY. IF YOU HAVE DONE IT JUST RIGHT YOU WILL BE LEFT WITH A VERY GLOSSY SURFACE PERFECT FOR DECALING. AFTER RE-NUMBERING I USE TESTORS DULL-COTE ON THE ENTIRE ENGINE. THE RESULTS ARE VERY GOOD…GOOD LUCK!
Thanks EMDSD40, I have a bottle of the stuff Kato sells on their website to remove road numbers and redecal, any idea if this would be along the lines of the 3M product that you use?
Rod
