Renumbering Kato SD40-2
Hi Guys,
How hard would you say it is to re-number the SD40-2? Where would I find decals?, or would i have to paint these?
Thank You,
mj
MIcroscale makes many different decals sheets with the correct color and font for most popular roadnames out there. To renumber it you simply have to remove the old number or numbers and wet transfer the new ones on top. There are a few ways to do this from sanding, painting over the old, using easyoff to remove the old number/s which ever way makes you feel comfortable. Now if you are doing a patch job painting over the old looks the most realistic. Number boards are much the same only the stuff is much smaller.
Massey
