repair of type 1010 35 watt transformer
Does anyone know how to take the Lionel type 1010 35 watt transformer apart. The power cord is bad and I need to replace it?
Childhoodfun- Welcome to Trains.com! [C):-)]
The plastic case is pressed onto the steel base, there are internal one way grippers that hold the case on. I have removed these by taking a two inch wide putty knife and wrapping the end of the blade with several layers of masking tape. Then insert the blade between the bottom edge of the plastic case and the steel base and twisting the blade slightly to put upward pressure on the case. Go around all 4 sides of the transformer and repeat the process, you should start to see the plastic case moving up from the steel base. Continue until the case comes off. Good luck. Fred Hachmeyer fred.hachmeyer@falconjet.com
Mine was a little different but the principle worked! Thanks a million!!
