Replacement can motor for HO brass engine?
I have a brass steam engine with a dead original motor. It is about 20mm long with 15 mm diameter.
I’m trying to find a replacement motor for this but I’m having trouble finding an online resource that sells round can motors in these dimensions? Any tips appreciated!
motor1
motor2
North West Short Line might be of help. It looks like a Mabuchi SF266SA motor would fit but not knowing the RPM of the old motor makes a big difference, the 266 is 7000 RPM.
The Mabuchi SF266SA is readily available on eBay for a couple of bucks.
Mel
My Model Railroad
Bakersfield, California
The Repower and Regear IO group might be of assistance. These guys are very knowledgabe on remotoring especially brass. The Mabuchi 266SA that Mel mentions is definitely the popular choice for remotoring HO scale at the moment, it’s an 18mm by 18mm square can. These can be found on ebay from Chinese sellers for about $3 or $4.
The other popular choice is 6500 RPM Minebea 15mm by 15mm square can motor. This one is liked for its slow speed performance, small size and high torque.
I also have a brass 0-6-0 that is getting re-motored and re-geared from it’s original stock open-frame and non-idler gearbox. Because it’s a shop switcher that’ll be doing low speed operation around a yard, and space is at a premium, I’m going with the Minebea 15x15mm motor.
Good luck!
A variety of coreless motors with small diameter can be found here, or one 16 x 20 mm here.
These motors are virtually silent, strong enough for so small locomotive, and will considerably improve running, under condition that the rest of drivetrain is in perfect condition.
Hrvoje
While I have yet to repower one of my brass locomotives, I did buy several of the Mabuchi motors that Mel suggested and did some experiments. I believe they will work as excellent motors for repower.
-Kevin
Hi there. Finding a motor that will accomodate both a gear and a flywheel might be a bit of a challenge, if that’s what you are looking for (I like flywheels myself). In addition to NWSL, MicroMark offered some lately at a reasonable price, as well as flywheels.
Simon
Assuming I get the motor replaced and working, can someone recommend a DCC sound decoder to convert this engine? I’ve never done that before but I think this would be a good first project.
Assuming I would have to:
  1. Put decoder/sound in the tender
  2. Electrically isolate the motor somehow
  3. Run wire(s) from tender to the engine, with several plugs?
Any specific decoders with sound components appreciated!
Well you have several choices for that- The two most popular are ESU and SoundTraxx. And there is TCS too. Zeno is another manufacture that makes decoders. Each one has support items for their products.
I would add Digitrax to the above list. And while plugs between the locomotive and the tender are a really nifty option, they are not absolutely necessary.
Simon
