I have a number of cars from when I was a kid that are in nice shape, except for broken steps.
I bought a few packages of replacement steps. They are very thin. At the top of each side of the step is a tiny tab, presumably for mounting into a hole.
The smallest bit I have is a Walthers #74. It is tiny, yet it seems too thick to drill into the bottoms of the cars. Alternatly, I suppose I could try gluing the small tabs to the outside bottom of the cars.
I am curious if anyone has tried this, or if there are better ways of replacing steps. Does anyone make entire ladders, including the steps, that can be glued to the existing ladders? In comparing cars from different manufacturers, it seems that the ladder steps do not line up.
I have also thought about taking some metal ladders from broken cabooses and tank cars and using these to make steps.
What are your thoughts?
