My Lionel 56 needs the worm gear located on the axle below the motor replaced. Looks like a project. Anyone ever do that? Must be somewhat common as repo 41-12 gear are easily available.
You will need a wheel puller to remove the wheel from the axle and a wheel press to replace the wheel after you replace the worm gear. You will also need to clock the w
I did one on my 2343 I think. I know I did one one time. But it has to be at least 5 years ago. Seems it wasn’t that hard of a job but don’t remember the details.
