Have some older Tyco (Mantua) rolling stock with metal trucks but plastic wheels that I want to put new metal wheels into. Is there any “best” technique for getting them installed other than gently spreading the side of the trucks enough to get things out and in again? Plastic trucks seem a no brainer but maybe there is a trick dealing with the metal ones.
Don’t have a set of spreading pliers but realize that may be a neccesary purchase in the near (if not immediate) future.
It has been a while since I have done somthing with Tyco trucks, as I recall, the sideframes are pressed into another metal piece making them rather rigid. Probably the best thing to do is to replace the metal truck with plastic truck and install metal wheels if they do ont have them.
I have to agree with Mr Beasley. I just upgraded on old Mantua/Tyco car. I tossed the trucks and body mounted Kadee couplers. I used Accurail plastic trucks with I-M metal wheel sets. This combo provide the best value for a free rolling set of trucks. Trying to force new wheel sets in those old metal sideframes may result in either too loose or too tight a fit. And a ‘truck tuner’ is not going to ream out old pot metal sideframes!
I was visiting a friend in the States, and we went to a local train show. I had been looking for some gondolas to kitbash into CNR prototypes, but forgot that they were supposed to be Model Power gons, and bought a number of Tyco and Mantua gondolas, at a buck-or-so apiece.
When I returned home and realised my error, I decided to simply use them for my freelance home-road.
First job was to strip the paint…
(the darker one in the pile is a Mantua, with a cast metal underframe)
I added some very basic underbody detail, just the stuff that might be seen from trackside, as the upper level of my layout is at roughly eye-level…
For the Mantua car, I left the cast-on AB valve and air reservoir, but replaced the brake cylinder with one from my “parts department”. To add the brake rigging, I cemented blocks of styrene into the centre sill - much easier on small drill bits than the cast metal…
Using my X-Acto and a small square, panel joints were scribed into the interior of the sides…
All of the sill steps and cast-on grabirons were removed and replaced with metal parts…
I like Wayne’s statement, “Tyco is what you make of it.” I think Tyco, Life Like, had a lot to do with getting many into the hobby. That first trains set!
I haven’t run a Tyco loco since my first Athearn, but some of the cars remained in service for years. Of course I’m talking the plastic truck models.
There is a huge Tyco following. I learned that.
I certainly wouldn’t mess with any with the metal trucks.
Upgrading these few Tyco cars is more a labor of love than anything else. They are from my first HO scale set my dad got me when I was about ten. Up until then I had operated a Lionel set that had originally belonged to my older brother - although I always felt my dad had really bought it for himself. I’m 65 now and all of the original Tyco cars are still on my layout - but definitely due for some TLC. At this point, I wouldn’t dream of dumping them.
I have a couple of these Morton C.V.s running on the LM&E. However I was wondering are they fairly scarce ? as you hardly ever see any pix of them on any forum.
