Here’s the plan for version 2 of my layout, construction should start next month. The space is 16 x 22’ and I plan to make this a Nolix: climb starts on the left end of Tidmouth (+x.x symbols denote elevations).
Note: the track in the lower left that crosses the entry door is climbing to the second level. By the time it gets to “Tidmouth” it should have gained about 11" elevation.
Note that logically the line goes Knapford - Tidmouth - Maron - Maithwaite - (future upper deck). At Tidmouth there is a branch to Brendam, which has a port.
Would really love feedback on this. Particularly I am worried i don’t have enough staging (where?) and not enough space for scenery as everything feels narrow.
Not even a box above. You gotta keep trying. If the image is on google, click on the image there a few times until you get to the root photo. Then copy and past that location.
Just for fun… Google “GRS Model-5” and check out the images. [swg].
Can’t embed a Google Drive file. Even if it’s public, you have to have a Google account to see it. When I clicked on the box, it made me log in to my Google account, and then it showed.
Know I think of my layout 8 X 4 that I was really proudof, and think of selling our house to buy a new one with a two car garage! Very impressive plan.
I want to add a 40" by 66" extension. The lower level will be used to park passenger trains, and the uper level maybe for an additional freight yard or else …
Well, photobucket site is not cooperating! I can’t fine the app I used in the past to upload images and although I have the image uploaded I can’t seem to copy the IMG link.
I can open it from one of my computers but not the other. Unfortunately I am on the “other” computer so I can’t provide specifics.
It looked like you had a very heavily passenger oriented layout with the major passentger terminal on a branch off the junction. That means you will have to back trains up the branch since I didn’t see a way of turning them to return to the terminal once they left.
The small yard at the junction will be able to support one local at a time if that’s the amount of industry work you had in mind. If I were going to add staging, I would add it behind the passenger station, either raising the passenger branch or putting an elevated city above the staging yard. Probably could make the benchwork 6" wider and add 3 tracks for a thrugh freight in each direction (to move cars in and out of the local yard at the junction) plus maybe a coal or other unit train, or some sort of special train.
Dehusman: Yep, you decoded it right, it is passenger themed! but does have a lot of cargo as we’ll with agribusiness at Maron, Brendham docks , a food products factory at Knapford, another factory at Maithwaite and a large industrial yard on the upper deck. So it should work both ways.
The main terminal (Knapford) is not on a branch, I think my updated explanation is better.
I suggest you read Tony Koester’s book on Multi-deck model railroad. It looks like he addresses many of the issues you’ll have to face. My comments are based on this book.
won’t it be difficult to follow a train from Maitwaite to Brendam because of the curved trestle is in the way.
There’s a lot of open space in the middle of the room. It looks like the pennisula with Knapford could have a loop at the end so that tracks are on both side.
if you could attach the pennisula to to wall on the left side, instead of the right, the track could follow a path down the left wall halfway, out along one side of the pennisula, back along the other side of the pennisula, and then back the left wall and continue counter-clockwise.
The pennisula could be multi-deck. This would not only lengthen the track plan, but also allow an operator to follow a train around the layout without having the curved trestle in the way.
Tony comments that siding require flat areas to avoid spotted cars from rolling. For example, the elevation at Maron should be 5" at both ends of the sidings.
you’ll also need to determine if there’s enough length with the flat areas at sidings to achieve the height differences for a multi-deck layout, including the thickness of the desk.
Tony was mostly concerned with running trains. He was more interested in having station sidings that trains met than having larger industries that needed to be switched. He only modeled the 100’ (foot and a half) around the track which required minimal scenery and makes the point that building a multi-deck layout is very much like building two layouts.
Tony also describes how he routed tracks around appliances like your water heater.
Thank you so much for your detailed critique! I have read Tony’s book a while back, but not recently. I will find it.
Valid point. Although train leaving Maithwaite to the right and up (in the image) will be 12" above and on the upper deck. Still the same issue you point out.
Negotiations have resulted in a large central area to be preserved for kids to play, or seating. I am happy I have this much!
This is a good idea. It might eliminate the trestle. I don’t really like the location of the trestle as it blocks off a path into the room. I will think about this … I will need to route a loop (min 5’6" diameter) to turn around.
This is the plan … I did not label it, but the track starts climbing again after the switch at Maron.
[quote user=“gregc”]
I will make the upper deck 0.5-1" thick in this area and this portion will not have any switch machines. Another approx 12 feet (3" height gain) later, I will go to “normal” bench work. I may have to mounta a couple switches on top (Disguised inside buildings) to make this work.
Neat idea for a layout! Even though I consider myself a prototypical modeler, I think the Thomas series is great! Will this be a Great Britain railroad or will you be running American stuff? What railroad? Either way, it looks like a decent plan. It would be better to be able to follow a train along as it went around the room, but you could duck under the trestle or simple stop the train, walk around the peninsula and then continue to run the train…it’ll give that ‘standing by the tracks, waiting for the train’ feel. I only see the one plan (in your original post), is this the updated plan? Is there anyway to build a peninsula over the yard so you could follow the train? Sorry if you already addressed this issue, I can’t remember everything I just read whe writing this.lol
Cheers! I look forward to a thorough photo documentation of the planning, construction and running of the layout…who knows, you just might get a mini series out of it! Hahaa
Hi, the layout is visible to me and looks great. My only thought, from what I can see, is that you have many yards, but no industry to serve from those yards.
Delray- Thank you for the kind comments. The track at the basement entry does not form a continuous loop, it goes above Tidmouth (gains 12" going around the room once.) As such the first pass on the lower level should work ok for following around if one starated on the inside at Knapford. For the second level- you are right. But I think it’s OK because I might not get to the second level in this lifetime. It’s a compromise I am aware of after yours and a couple other comments.
I will run American contemporary equipment, but use words like “railway”, “signal box” etc to evoke some British charm.
Ted and CanadianKnight- actually a lot are stations- Knapford, Tidmouth, Brendam, Maron, Maithwaite. Attached to Tidmouth is a classification/staging yard and engine service facility. Next to Brendam is a port. Maron will actually be a single platform station with farm industries (elevator and fruit loading) on the two tracks. Maithwaite station have two spurs for a factory of some kind and Culdee fell is a logging branch line. Not labelled sorry …
I am updating based on all the input and will post a new one tonight.
shouldn’t the height at either end of any track where you expect to spot cars be the same? otherwise the cars are like to roll.
the bottom end of Maron should be 5" and the left side of maitwaite is 8.24". The curve between them looks about 30", making the distance ~45". I figure that to be a 7% grade (3.24" / 45").
