I have a quick resitor question. I’ve been wiring up LEDs in various setups for several months now. I’m currently working on a scratch built project with multiple series of LEDs setup. Between 4-5 series per building. The problem is, one of the models I did during daylight hours, so it was not until evening with the lights off I discovered I’ve chosen resistors too low for the exterior lights as they are taking away from the interior lighting through the windows. I would like to avoid refitting all 4 series on the exterior lights with alternate resistors.
So my question. Instead of said refit, can I simply add a single resistor were all series come together? I have the wattage covered with a resistor for this, but I am wondering if there are any complications to this, as I am still just surpassing the novice level with electronics.
I understand a lot of the basic do’s and don’ts of wiring LEDs with resistors, like never supply multiple LEDs in paralell with a single resistor, etc. but even though this situation seems to work fine in my mind, I just want to be sure.
Thank you for any advice. Hopefully to photo shows up correctly.
