Resistors do not have polarity. It doesn’t matter which way they are installed.
By the way, thanks for asking the question here. This is precisely what the forums are for, and personally I choose to encourage people to post here rather than suggesting that their question is somehow inappropriate.
The stripes are there to indicate the resistor ohms and wattage. A Google search can find charts that give this information, or just measure the ohms with a meter
Dave Wrote -The end of the resistor that has stripes closest to the end is the positive end and the more blank end is negative. Sure hope I am right. Am I ???
Not quite Dave but you are right in one respect, that the end that the color code value starts from is nearer to the end. Given the “panic” engendered by electronic boffins to those of us less experienced about polarity it is understandable you would have concerns. In short resistors, globes and non electrolytic capacitors are the only devices I know of commonly used by model railroaders that are not polar.
What is a good idea is if the resistor is protecting an LED, place the resistor to the positive end of the LED rather than after it. The voltage drop is the same across the LED but the protection is arguably better,
Hope this helps and lets keep some of the “silly” questions going and we will ALL learn something!!!
Regards from Australia
Trevor www.xdford.digitalzones.com for your interest and you might like the Hints and Tips and the basic electronic stuff
Relays and switches are also not polarity sensitive.
It does not matter which side of the LED the dropping resistor goes on, electrically it is the same (those various pesky ‘laws’ like Kirchoff’s and Ohm’s). It DOES make good sense to be consistent whichever way you do it, not from a sense of one way being better than the other, but from being able to come back later and recognize what you did. Same with any wiring, really. Keeps it easier to understand. It’s quite tempting, when you are 5 feet short of red wire on a Sunday evening, to splice in a spare piece of blue wire just to finish the project, but next year when you have a problem in that section and try to troubleshoot it, you will be confused to no end when the red wire you are traci
