I’m creating a new HO Layout. Backmann EZ Track and Digitrax Electronics. I plan to automate the switches using either AR1 or BXPA1.
I have a large Reversing Loop and inside that Loop, I want to create another Reversing Loop. Are there any issues in doing this, or is it just setting up the right blocks to prevent shorting.
I’ll say upfront that I’m a Computer Scientist not an Electrical Engineer or Electrician. My father was an Electrician and he taught me pretty well, so I do understand the fundamentals…but I can’t get it clear whether this is going to work. I’ve tried looking at many many layouts to see if I can spot a similar set up, but I just don’t know.
So, does anyone know why this absolutely would not work? If not, any suggestions on how to best layout my power blocks to facilitate?
Without seeing the track configuration, it’s rather difficult to determine what will or will not work. Without knowing what you are thinking of for a track plan it’s impossible to determine where the gaps for the reverse sections would need to be. DCC reverse loop are all about the reversing sections and where to put the gaps.
Theoretically it is possible for a reverse loop to be inside another reverse loop.
Providing a track plan will allow everyone to give you a much better asnwer.
It is certainly possible to create a reversing section within a reversing section. I use the term “reversing section” because it more broadly refers to situations where tracks wired in opposite polarities connect to each other. Reverse loops are simply one form of reversing section. As Lakeshore Sub has suggested, a diagram of your track plan would be very helpful in giving you advice.
Are there situations where this absolutely would not work? Sure, but those situations would only be caused by the configuration of the two reversing sections. The keys to success are the proper placement of gaps to prevent dead shorts and the length of the reversing sections to prevent confusion between the activation of the two auto-reversers at the same time.
You mentioned both the AR1 and the BXPA1. My advice is to avoid the AR1. It is an older auto-reverser that uses a mechanical relay to trigger the reversal of polarities inside the reversing section. As such, it is slower to react, defeating the whole purpose of reversing polarities.
I have no familiarity with the BXPA1, but it is a solid state device which is quick to react and trigger the reversal of polarities inside the reversing section. Unless you are strongly leading toward the BXPA1, you might want to consider the PSX-AR which many of us are more familar with and use on our layouts.
Let’s get back to the two primary considerations to make your track work successful.
To work properly, a reversing section needs to be totally isolated from the adjacent track work by fully gapping the reversing section. The same is true for a reversing section within a reversing section. Both reversing sections need to be totally isolated from each other and from the adjacent track work.
The other basic consideration is the length of the reversing section(s). To prevent confusing the auto-reverser, the reversing section needs to be longer than the longest train that will use the reversing section. In other words, you don’
To my understanding, you can only have one reverse module on a line at a time. If you have two hooked up to the same mainline, they would conflict with each other and would constantly be switching the polarity. Thats how ir was explained to me.
Now, as far as a reverse section inside another reverse section, yes, you can. You will have to put your gaps far enough outside the second reverse section for it to work. In other words, once you enter one reverse section, the polarity of both would have to change at the same time. Picture a passing siding in your reverse “loop”, if you have your autoreverser outside of all that trackage, you could have a big reverse loop with multiple passing sidings in it but they all have to switch together. If you are running two completely seperate mainlines then you can have two reverse modules at the same time but, the second you add a crossover from one to the other, the reverser will conflict with the other one.
If Im wrong, Ill admit it but, I dont believe you can have more than one autoreverse unit at a time.
I have four auto-reversers on my layout. I use PSX-AR units. The keys to avoiding conflicts between multiple auto-reversers are gapping and wiring.
First, each reversing section needs its own auto-reverser, and each reversing section needs to be totally isolated from any other reversing section and totally isolated from every non-reversing section. Properly placed gaps will accomplish this objective. Also, you need to be sure that each totally isolated reversing section is longer than the longest train that will pass through it. Show us your track plan and we can help you with the proper placement of the gaps.
Second, the wiring is critical. Each reversing section will have two wires from a non-reversing section connected to the input side of the auto-reverser. Any output wires from the auto-reverser should only be connected to track insid
There seems to be two (2) parallel (excuse the pun) threads generated by the OP approximately seven (7) minutes appart on Friday- -according to the time stamps.
Our OP, Ruckuss, posted three similar and somewhat related thread on Friday morning. We need to hear back from him, so we can further help. And a track plan would be most helpful so that we can visualize his track work.
Way back when dinosaurs ruled the earth and the layouts of modelers with little kids, it was understood that connecting one reversing section to another wasn’t a good idea. When you do that, both autoreversers will try to flip polarity at the same time, which would result in another short. I suppose more modern autoreversers might have adjustable delay timing that might alleviate this.
Simple question and simple answer is yes. An autoreversing loop can be installed within an autoreversing loop. At least using BXPA1. I have this installed and working perfectly thru a little trial and error. I didnt try the AR1 because i wanted solid state and to take advantage of the track detection feature
simple questions need simple answers. My layout is irrelevant to the questio
Thanks. This was helpful. I chose BXPA1 for solid state and have 3 reversing loops working perfectly. One inside another has no issues. Its all about the wiring…and of course gaps
