Responsibility for maintaining railroad crossings
I read in a TXDot document somewhere that the railroad was only responsible in Texas for maintaining railroad crossings, specifically the portion immediately above the cross ties and that was it. Not sure about crossing signalling systems.
I have noticed that when there is a grade crossing improvement project the railroads financial contribution is pretty tiny.
I wonder if that is the standard in all states or just Texas?
Along the UP West row in my western Chicago suburb, I see UP maintenance crews frequently working on signaling for crossing gates.
Who is responsible for the actual work on road crossings and their protective devices and who PAYS for that work can be two different things.
I suspect there are individual agreements between the parties on each and every crossing.
The general rule as I understand it is that the municipality (state, city, town, etc.) is responsible for the costs associated with any improvements on a grade crossing (i.e. upgrade from crossbucks to lights/ gates). The railroad then becomes responsible for any costs associated with the ongoing maintenance of those improvements. Said another way, municipality pays the capital costs, and the railroad pays the annual maintenance expenses. I’m sure there are variations to this arrangement in certain circumstances.
Prior to the pandemic, several of Norfolk Southern’s grade crossings here were renewed. Based upon the order the materials arrived in, and their “pre-project” placement…it appears that the railroad provided all new ties, as well as the molded vinyl flangeways. (there were bundles of ties placed for hundreds of yards in either direction for the crossing I am most familiar with, so it appears that NS doubled down on the scope of the project).
The City handled all barricades and traffic detours, and at least the asphalt work to the outboard sides of the crossing (street tie-ins) that I am sure of. I suspect they did all the asphalt work, but I’m just speculating there.
Years ago when they jointly did a grade separation in our downtown, the City was responsible for all street and sidewalks, the railroads imported all the fill, built the embankments, and laid the track, and the state paid for the actual bridge spans . This last paragraph provided just as illustration that the parties can work together.
When Ames IA had the automated horn system, since removed, the city was the ones who maintained the horn system. The railroad maintained the actual crossing signals and gates.
When the indicators showed that the AHS had failed, we would report it to the dispatcher. Who in turn often said, “I’ll let the city know.” When the system failed, we would blow the engine horn for the crossing.
Jeff
In the past when this question of " responsibility" has come up. It has been noted that the question of ‘responsibility’ was laid at the feet opf whatever ‘civil’ uitilty was involved.
The specifics of the type, and location of the rail-highway crossing were laid at the specific government entities door step. { Probably, after consultations with the specific railroad envolved. as to location, and its’ detailed specifics} You can bet the individual specifics would be complicated and detailed in meetings with the governmental and various railroad’s organizational entities.
Growing up in Memphis, Tn. in the late 1960’s I was aware of the entracies of the processes of rebuilding and upgrading the railline east from N-S’s Forrest Yard to Collierville, Tn. Many crossings and several municipal entities and County governements were envolved.
Out here in Kansas, as part of a Planning Commision job, and a local highway re-construction, as well as a local land-owners request for an automated highway-Rail crossing; I gpt schooled on the costs of that crossing (approx: $250,000.)…
Ultimately, it was decided that whatever the requested improvements (signalizations) were needed in each case. The governmental entity would pony-up the costs for that ‘imporovement’ and the railroad would order the specific equipment they desired, and then the railroad would install said equipment to their requirements.
When the specific equipment was installed and working as required; the railroad would maintain that equipment, make repairs as needed, and keep it functioning as designed.
Until last year I was a railroad public projects manager who had responsibility for four states at one time or another (3 at a time). Every state I worked in had some kind of a law that said the railroad was responsible for performing the maintenance of what is referred to as the “crossing surface” - the rail, ties, and ballast, and the timber or concrete panels OR asphalt directly on top of them. In one state this responsibility actually extended a little bit past the ends of the ties - something like 4’ from each rail, if I remember correctly. In most cases, the railroad was also responsible for restoring the pavement that gets removed when the crossing planks are pulled, as well as adjusting the road approaches for any change in the track elevation.
In practice, the railroad did the rail, ties, ballast, and planks 100% of the time, and did the asphalt approach work maybe 75% of the time. (We don’t use asphalt over the ties for crossings like some other roads do.) The rest of the time the road authority did the paving. Who did the paving depended on things like: was the road being paved anyways as part of a larger project? Did the road agency have its own paving crews? Was the agency contributing paving as part of it’s contribution (see below)?
Traffic control (barricades, detour signage, etc.) was like paving - sometimes the agency did it, sometimes the railroad hired a contractor for it.
Who was resp
(1) in every state, there is an MOU somewhere where the feds defer to a local state agency (RR Commission/ PUC/ DOT etc) to act as ombudsman at a crossing to apportion costs and responsibilities. (Who owns/ operates/maintains/pays). It also figures into signage, drainage and other considerations. Usually, but not always, there is a license agreement/contract and a PUC docket/decision that can be found for each crossing or grade separation. The wives tales, wrong hearsay, lies, fraud and bad assumptions that are out there are downright scary.
(2) the railroads typically pick up the maintenance and mandated routine testing of the signal system. (a cost thatis NOT included in the claimed “pittance” above)…Tends to be a hefty annual budget.
(3) Railroad signalling and highway traffic signaling are very specialized critters, best left to their individual technicians and don’t interlock well at all (where they do, there are a rediculous amount of headaches)
(4) The bulk of the damage to crossing surfaces is due to impact damage by the overweight highway vehicles (compounded by the lack of concern over approach grades)…Agree with Peltier that the only place asphalt should be in a crossing (a dynamic structure) is under the ballast as as an underlayment, never over the top of the ties or touching the rail. (and then you have the goofy state highway rubber-tired engineers in Oklahoma with concrete poured over and up to the track section…no understanding of the dynamic track structure and track modulus).
(5) Most state statutes have codified rules with something to the effect that maintaining the crossing surface by a railroad ends at two feet beyond the outside of the rail plus anything between tracks.
Every state is guaranteed to have its own weirdisms. Railroads as well. Iowa and its town hall meeting/ group-hug ideas can get really weird.
You don’t dare open, close, change or improve a crossing without the permission of that PUC , RRC, DO
Not to mention where crossings are built on railroad curves that have superelevation.
Here in Pennsylvania, the railroads maintain the crossings. Twice the CSX has rebuilt their crossing on route 30 (The Lincoln highway) which is an exceptionally busy road since it is the only road connecting Philadelphia and Pittsburgh without using the Pennsylvania Turnpike. There are a number of small towns between the two cities that commuters and trucks go through.
RE: Dennison IA all over again
There is one of those in Fort Meyers, FL on the former ACL formerly used by the West Coast Champion now owned and maintained by Seminole Gulf Railway. Forget the street though but rode over it on their tourist train with the old Bay Colony Coaches with the springs that should be replaced. They rocked back and forth so badly you could not maintain your balance if you were standing up and we were only doing 10-15 mph.
Today - Main Street crossing in Sykesville over CSX’s Old Main Line. Cross it most every day - you just don’t want to do it at speed.
https://earth.google.com/web/search/sykesville,+md/@39.36405452,-76.96892874,115.24561795a,276.78190837d,35y,-0h,0t,0r/data=CnkaTxJJCiUweDg5YzgyNWE4MDNkMTBlNzU6MHg4NDg1ZGVjZjJjOWUyMWRjGZLDzOPVr0NAIT7fYLnvPVPAKg5zeWtlc3ZpbGxlLCBtZBgBIAEiJgokCXPoIxJR1zlAEVHd1GtsyzlAGU4f9v9PB1TAIYbxFjw0DlTA
Wow - no gates…
Nice old station, though.
Track speed is 25 MPH. The bridge just South of the crossing is a replacement for the one that got washed away in the flood occasioned by Hurricane Agnes that hit the area in early June 1972. Agnes washed out most of the Old Main Line where if followed the Patapsco River ie. from its start at Relay, just outside Baltimore all the way to East Plane. Railroad was not rebuilt until 1975 and had an additional wash out experience in 1976 that had it out of service for several months.
During the construction of the B&O Sykesville was the location of a riot between the Irish workers and the German workers that took the Governor of Maryland calling out the 1830 equivalent of the National Guard to quell the riot and separate the combatants.
For the past 30+ years the station has housed some highly regarded restaurants.
