Back in the 50’s, while riding the B&O’s National Limited from Washington DC to Cincinnati, while in West Virginia, the conductor came into the vestibule where I was looking out the Dutch Door and activated the retainer valve just before we started down a major grade. Back then, the Lawyers had not struck. Watching the train go through the night, the headlight and mars light shining ahead and with the light from the windows lighting the trees and the road bed plus the orange glow from the brakes and the sparks flying off the wheels was a sight not to be forgotten. I also have read about the requirement for freight trains having their retainers set up before descending grades. I know that retainers were to allow the train line to be recharged without releasing the brakes.
My question is do trains still have retainers and are they used or have dynamic braking systems and/or the newer feed valves that can maintain train line pressures eliminated their need?
Freight cars still have retaining valves. Dynamic brakes, however, have become much more powerful and more widespread so the actual use of retainers today is uncommon. The delay while a conductor turns up the retainers on a specified number of cars at the top of the grade, and then a second stop to release them at the bottom, is incompatible with efficient operation.
There may well be a few specific long steep grades with heavy tonnage where they are still regularly employed. Otherwise they are mostly a back-up system available if the dynamic brakes become inoperative for some reason.
At least on my carrier - crews are not taught how to handle trains turning up and turning down retainers. They either have enough dynamic braking to decsend the grade or they wait until sufficient power with working dynamics are available to go down hill. A signifigant amount of our manned helper engines working time is assisting under dynamic braked trains down the various heavy grades.
As has been stated by working railroaders elsewhere within this Forum, using dyanamic brakes instead of relying on retainers greatly reduces the expense of replaing brake shoes often. And improves train handling increasing smoother operation. Also stated elsewhere, all Amtrak road locomotives have dynamic brakes.
One thing to check for when stopped by a hot box detector for a hot box or hot wheel is the retainer. Once in a great while one will get turned to one of the retaining positions and cause the brakes to stick on. (Which is what they are supposed to do.)
The rail train lifting the rails on an abandoned CNR subdivision experienced unexpected train handling. On investigation the reason was identified. The encroaching shrubs and small trees were turning the levers and setting the retainers. While the crew never had to set retainers, for the rest of the program they periodically had to release them.
The Mars light was in the OP description of the trip in which the retainers were used, they were not related to the retainers themselves. Reread the original post and you will find where the Mars light was mentioned.
Legacy B&O passenger engines did not have MARS lights, however, in the late 60’s until Amtrak, a number of former C&O engines were put on the B&O roster with B&O engine numbers - those former C&O engines did haver MARS lights. If the trip was truly in the 50’s there were no MARS lights on B&O engine.
The mind, as we age, does funny things with our memories.
100 loads of frac sand 14000-15000 plus tons on a 1-almost 2% in some places with distributed power, newer big modern locos, i use a minimum reduction only with dynamics and the train behaves very nice. easy to handle, thats how good the dynamics work.
Last time I looked (5 years ago ?), the Norfolk Southern timetable required the use of retainers on any train with a TPOB (Tons Per Operative Brake) over 125 [EDIT: various provisions are effective at 100 TPOB, and “Average (TPOB) must not exceed 140 tons” - see links below] going eastbound down “The Slide” (2.36%) from Gallitzin through Horseshoe Curve to Altoona. I’ll see if I can find a reference to that.
NS stopped and set retainers before descending Saluda until operations ceased in 2001. This is a training video from 1984 that describes the procedures to get a train safely down the mountain, combining dynamic braking with setting retainers.
Stories about reainers, exist and, are they necesarry?
Yes, , cause, but not often, the DB control circuit will trip and there’s no dynamic braking, but if the air brake supplement the DB’s when the ,circut breaker or some other problem, caused the failure, there’s minimal time to increase the air brake app.to adequately control the train.
Then the brake pipe leakage increases the application and when the application is too much, brake recharge and release needs to happen. The retainers slowed the release,. so, (no DB’s) leakage, release and recharge, You’ve got to, with retainer slow the release during the recharge
USS developed the unique “Orinoco” system for their ore lines in Venezuela where they actally had to take loaded ore trains down a steep mountain. There is a second brake line from the locomotive that is valved into the release side of the brakes on each car. This allows a back pressure on the brake system to be set up from the locomotive, effectively giving continuous control of the retainers to the engineer. The brakes can be set and released from the locomotive while the train line remains fuly charged, and the normal and emergency function using the train line still works to set the brakes if needed.
This system is still used on the CN operations of the ex Missabe road.
