I am returning to model railroading after being away for many years. I am pulling out my tracks and trains and will set up a 60 x 48 layout.
Before doing it I have searched answers for two issues: I have searched what is the best product to use to clean track, I read hand ‘track eraser’, liquid cleaner and even viewed a video showing sporadic use of automatic transmission fluid
Also best way to clean metal wheels
Maybe more questions later. Thanks ahead for any feedback…
by cleaning if you just mean oxides i use a rag with whal oil followed by a rag soaked in 96% alcohol, if its glue /paint or other stuff it takes a bit more agressive cleaner(bright boy or fine sandpaper)
for wheels i use 96% alcohol on a paper towel laid over a section of straight trackrunning car back and forth moving the paper a bit after 3 or 4 swipes
Whal oil? There is whale oil, which they probably sell only in Japan and there is Wahl oil for hair clippers. I don’t get the rational for oil, but if it works for you…
OP you might want to research gleaming, a high polish of the rails. Other people use a bright boy and some swear by the Walthers track cleaning car. There are also some liquid tank cleaning cars. There are products that claim to clean protect and increase electrical conductivity. Sounds too good to be true, but I have not tested so I’m a just a guy at the end of the bar
If there was one best solution, we would all be using it.
Edit One more thing, some of us weather rails and wheels with acrylic paints. I would use a 70% solution rather than high test.
really old track but I did nail a circle and ran my diesel and older units on it…works ok…track do need to be replaced, having trouble lining some of them up etc…I did it to see what loco was working…Looks like new code 83 is in the buying column…thanks for asking
