Perhaps I designed a 4 x 8 in ignorance. Strike that. There’s no doubt. I set the layout up for parking trains head-in now all my set-out moves involve run-arounds.
I put all my switches into one controll panel so operating either has to be a two person job, or you do a lot of walking abck and forth from one side of the layout to switch turnouts, to the other side to uncouple cars.
So all you newbees that get the urge to build a 4x8 layout, you will do better all the way around to make your layout 30" wide and go along the walls. You will be able to do so much more with the same space. (Add 30" walk around room to all sides of your 4x8 layout and you have a 9’ x 13’ space you are occupying. ) Plus it will be so much easier to operate you railroad.
I started this thread because it seems that the first layout people want to build is a 4x8 layout, I think they should be able to see the down sides.
Please add your observations.
