Reverse loop fixed- both
[:I] The Walthers #6 double crossover with a Tony’s PSrev is working perfect.
Broke rule #1 of wiring:
Thous Shalt NOT use Stranded Wire for frog power, (stray hair was causing the breaker to trip) a little file work and all fixed.[:I][:I] MY FAULT!!
Probelm #2 MRC auto reverse: the RELAY that works the reverse is NO GOOD that was the buzz and hum. I hooked the PSrev to that segment which is far enough away not to cause a problem, to the SAME RSrev as the double cross, and it works perfect.
DO NOT DO THIS AS A FIX this was a TEST and not a TIP on how to do it.
Sorry for the wild goose cahse but your ansers got me looking at the wiring, THANK YOU again Forum.
Take Care
George (middle name mud on this one) P.
