I need help. I am working on a midsized ho layout. It has 2 reversing loops that are at either end of a section of track. I am using Atlas Switch Machines on each of the Atlas turnouts at the entrance to each reversing loop. I am using a an NCE Power Cab DCC Starter Set. There is one Power Block that is divided into 3 power districts - one for each of the reversing loops and one for the connecting track.
Each reversing loop has a DCC Specialties’ PSX-ARSC circuit board that provides circuit protection, polarity reversing and turnout switching. You can go into each loop 2 ways and come out 2 ways - depending on how the turnout is switched. I am not having any problem with one of the loops.
The loop that is having a problem never causes a problem when the train is entering it - no matter which way the turnout is configured. When the train is exiting the loop and the turnout is switched, there is no problem. When the train is exiting the loop and the turnout is not switched there is a problem. The locomotive exits the loop, the polarity is reversed and when the train reaches the frog it stops for a short time and then proceeds. If I stop the train after it has crossed the track insulators and before it hits the frog and then start it it continues without a problem.
Any ideas out there? I am not very experienced and I have no idea what is happening. I have tested the voltage on the track in all areas around the exit to the reversing loop and the turnout. The voltage and current are constant. I am using a DCC Specialties’ RRAmpmeter III to test the voltage and current.
Please tell me this is not a poltergeist.
