Is it okay to put multiple power feeders into a reversing loop controlled by a digitrax ar-1? I know that you connect one set power leads to the ar-1, but can you connect multiple lead to each individual track section. It is a rather large reversing loop. Thanks in advance Brian
Sure, as long as the feeders are part of the same reversing loop.
David B
thank you kind sir for the quick response
