Hello guys, just thought I would provide a review and a follow up to a previous post. Keep in mind these are both used so previous maintenance may come into play.
For those not familiar I am new to the hobby and recently ordered two used power units, what I found out were an Atlas SD35 and a Athearn BlueBox SD40. To my untrained eye these locomotives share more similarities than differences.
Weight seems good on each.
Sound wise both are heavy and run with a good low revving tone. The deeper note absolutely blows away my Life Like Diesel GP38 by soo much they sound similar to my ear.
Size wise the SD35 is 8 inches (20cm) and the SD40 9 1/2 inches (24cm). Both ran through my 18 inch curves and IMO looked good. The opinions on size make sense though, the larger Athearn locomotive might look out of place on my short spurs, or at least like a road locomotive do a switcher’s job. I think I noticed increased rolling resistance in the curves and it found and derailed repeatedly on kinked section in a curve the shorter Atlas locomotive handled. The 9 1/2 inch SD40 is probably the absolute largest I should purchase.
Pulling they both seem similar. The larger SD40 might have a little more weight so it probably gets an advantage even though my railcar fleet is not big enough to stress them yet.
Throttle response and low speed function are very similar and both run with less power than that previously mentioned Life Like unit.
Speed can’t be that important especially considering the age of the locomotives but the smaller SD35 is just a tad faster at all power points. It caught the SD 40 after quite a few laps.
Finish quality is similar, I would give the nod to the SD35 for having more detail but if they are not both in front of you then you might not notice. Biggest thing I noticed is the Atlas SD35 has flexible plastic hand rails and the SD40 hand ra
