Revolution Linking Question
Revolution question for the group. I just got a set of Aristo FA’s that I am converting to Revo control. I already have a few locos that I have setup and I have them listed on 2 different controllers. I can control my current locos with either handheld. When I programmed this latest unit I got it to link with both handhelds and it ran. I buttoned the loco back up and now only the last handheld I programmed will link. What did I do wrong or forget to do.
Jim Bartelt
Did you assign each loco id to a cab?
check the throttle that does not work, and see if the cab is still there?
the unlinking has to be at the throttle end.
No offense, but did you try both throttles after the “second” link? (In case your second link destroyed the first link)
Greg
