i recently recieived a Rivarossi 2-8-8-2 Mallet from grand father. I would like to know what roads used them adn for what services. Also what type of maintence should i do on it (oils, motor cleaning, and wheels). what woud this model get for a price in retail shops…
I did have a 2-8-8-2 Mallet, Norfolk & Western. I bot it in June of 99 from Modelexpo of Hollywood Florida who at the time(no more) had the distribution franchise. Walthers of Milwaukee is to assume full distribution/sales/parts.Go to the walthers site, www.walthers.com,click on product news, then click on Walthers reaches agreement with Rivarossi. I paid $178.00 including shipping and they will probably go for a premium over that
when & if you see them advertised. As far as lublication, DON’T OVER DO-DO IT SPARINGLY. Check
out your local hobby shop if avaivable for recommended lubes/grease. In as far as the clean wheels, I would dampen a thin rag(T-Shirt) with rubbing alcohol and place the loco on the live track and place the loco down on the dampen rag
and let the driver wheels spin. You will have to
clean the front/rear pilot contact wheels probably
with a saturated Q-Tip. I can send you the Rivarossi sheet that came with my unit, but it won’t tell you much. Here’s a recap of it. The “Norfolk & Western built its last class Y6b 2-8-8-2 Mallets in 1952 to work the coal drags over the southern Appalachians.”
"Among the various types of articulated Mallet locomotives, two of the most famous were the Y6b of the Norfolk and Western and the EL-5 of Baltimore and Ohio Railroad. Both were built by Baldwin locomotive works at Roanoke Va. These locomotives derive from Baldwin’s early types built between 1918 to 1920, for the United States Railway Administration, U.S.R.A.).
These locomotives worked on the “steam compound” system, that is, the high pressure rear cylinders exhausted into the low pressure forward cylinders, so the steam was used twice.
Although this system was very efficient when running, the exhaust from the rear cylinders was not enough to power the front cylinders from a dead stop. Steam was fed into the forward cylinders via the generator feeds through a special low pressure reducing valve.
Charles,Did you know that the N&W used Y6b’s on local freights and mine runs? Seems that this carried into the diesel era as I have seen ALCO 630’S switching the Portmouth,Ohio yards in the late 70’s.(?)On the NS I have C-40’s working local freights.Thought you would like to know.
