Rivarossi 5104 Turntable & Power Supply
I have a Rivarossi 5104 turntable, a 4202 power supply, associated cables and a 12VAC adapter all required to install above mentioned turntable. I need help in elecrtically wiring this turntable to my layout. I have a DCC system that uses 12-14VDC. Is there anyone out there that has wired this turntable?? I have contacted Hornby Hobbies in the UK, the Rep for Rivarossi and have received no reply from them or anyone else. I also have a copy of a MRclinic column which offers no real help also. Please respond if you can help.
Wayne Lalevee, Pinckney, Michigan
[#welcome] to the forum. Your posts are delayed in moderation for a while. As a result when they are approved, they appear not when approved but back in time when you posted it. If that makes sense. My reply will make it “fresh”
I found a thread here: http://www.tycoforums.com/tyco/forum/topic.asp?TOPIC_ID=15720&
Good luck with it.
[quote user=“BigDaddy”]
Welcometo the forum. Your posts are delayed in moderation for a while. As a result when they are approved, they appear not when approved but back in time when you posted it. If that makes sense. My reply will make it “fresh”
Good luck with it.
I have the same idea for a Fleishman 9152 N scale turntable. It should work.
Ira
