I have a Rivarossi “Red Box” DCC-Ready FEF-3 that has an NMRA 8-pin socket in the locomotive under the removable sand dome. The space for the decoder is not very big (15x30mm) so I probably need a “micro” size decoder. The problem is how to add sound. I took off the boiler (a task in itself) and looked closer at the space available inside but everything is so tightly fitted that it would be almost impossible to even get WIRES out of that area. So I was thinking that one way to do it would be to put a non-sound decoder in the space provided in the locomotive and then add a sound-only decoder in the tender.
How well does the dual decoder thing work? Anything I need to know or watch out for? Any suggestions would be helpful for a combination of decoders that will “play well together” (i.e., compatible CVs & functions). Or does anyone have any ideas on how to get a couple of speaker wires out of the DCC-plug area of this locomotive?
One combination I’m looking at is a LokPilot decoder for the locomotive and a LokSound decoder for the tender. Since they are from the same company, I would assume the default function assignments and CVs are compatible. As far as I know though, LokSound doesn’t make a sound-only decoder so this would be a more expensive way to go. I’m still looking at what is available from Soundtraxx, Digitrax, QSI, Zimo and TCS. I assume mixing products from different companies makes things more complicated.
To program both decoders I heard about a trick of assigning different short addresses (1 and 2 for example) but the same long address. That way both can be set up separately then CV29 set to change to long addresses for operation so both respond at the same time. Anyone have any experience doing this?
