Rivarossi FEF-3
Is there an easy way to put sound in this locomotive?
Check out the MR review January 2004.
Per MR.
"A decorder socket is located under the combined steam & sand dome, which is removable. For actual decorder install, however it will be best to remove the boiler.
However the instructions don’t mention that the boiler can’t be removed without
disconnecting the three metal pipes from the feedwater heater atop the smoke
box, and the metal reverse gear reach rod.
The retainer holding the feedwater heater piping is easy to remove by pushing it out from inside the smoke box.
The front handrails would easily slide out of the stanchions on the air compressor
shield as the boiler is lifted, so there’s no need to remove the stanchions.
DCC sound install, access to the tender is improved-front and rear tender bulkheads
are not glued and can be easily removed".
thanks …but let me put it this way has anyone here ever put sound in the new FEF-3
