Road crossing signals
Looking to install cross buck road crossing signal/alt flashing lights (led). Any suggestions to brand? Checked out Tomar and NCInd. but outside of a thumbnail photo neither gives details (need addt’l flasher unit/power supply/led size). I’ll be using separate power supply triggered by tortoise aux switch. Don’t need sensors. Road crosses a siding and only need lights to flash when turnout is thrown for siding.
Seems simple enough. LION would NEVER consider buying such a thing (Him cannot afford such stuff), but him would make the mast of a piece of 1/16th" welding rod, may the wooden cross bucks. Him can prind signs on computer as small as 2 point type. I suppose I could do one point, but tha point is moot, since your viewer could not read that. LION would make the lights out of small LEDs but him has a supply of Bionix lighted ear curettes… pricy but one used LION saves them for the layout. They would make a good pinpoint sourse of light, but I do not see how they could be used in your application.) Cheat and use flashing LEDs otherwise you will need to buy flashing equipment, far more costly even if more prototypical.
LION uses the color laser printer of him to make all sorts of signs for the layout of him, and very realistic the appear, unless you get out a magnifying glass to see what I actually printedn on the sign. Such as: “No Trespassing on the Tracks you Dumb Jerk”. Nobody has called me on them yet : )
ROAR
I use the Tomar Indutries crossing signals (#H-862). Two signals come in each package. You need an Alternating Flasher unit, and I use the Circuitron #FL-2 unit. The alternating flasher unit can control as many crossing signals as you want.
The Tomar Industries crossing signals are beautifully designed signals, and they look quite realistic on the layout. The flashing red lights can be seen from both directions.
The Tomar Industries crossing signals come completely assembly and are ready for placement on the layout. They simply need to be wired to the whatever actuator you choose to use. Don’t forget to add resistors to protect the LEDs.
Depends on the railroad and time. …
Slammer406,
How good are You with soldering and building kits and patience?? If You have some of the skills necessary and some patience, 30 watt pencil soldering iron, rat tail file, some CA. Oregon Rail supply has some really great crossing flasher kits. They come two (2) in the package with all needed parts, Led’s (3mm) and such. I picked up two pac’s of them and where they will be, it will be impossible to use sensors, so I am just going to use a on/off switch on control panel. For the flashing circuit, I am using Ngineering # N8013 Alternating Flashing circuit. You can use any power supply with the circuit, as long as You don’t exceed 16 vdc.
E-bay has the #113, or there are many other places to get them if interested. I decided to go that route because at the time every other MFG. was out and I thought they were too much money to begin with. The kits are not that hard to assemble.
http://www.ebay.com/itm/OREGON-RAIL-SUPPLY-113-2-CROSSING-FLASHERS-/301788469754?hash=item4643fe99fa:g:ZQUAAOSwo6lWOOrO
http://ngineering.com/lghting%20effects%20for%20the%20railroad.htm
If You look at the right side of the pic’, laying down on it’s side, is one of the crossing flashers from the kit. I was testing it. Not a very clear shot though.
Like I said If You want to try them, not really that hard.
Take Care! [:D]
Frank
I went with NJ International crossings controlled with a Logic Rail GCP and operated with a Tortoise. I also use NJI crossings and a NJI signal bridge. I recently bought a pair of Century Details HO-116 Wig Wag signal kits, I’m working on making them operate with a pair of micro motors.
http://melvineperry.blogspot.com/2014/06/june-4-2014-logic-rail-gcp.html
Mel
My Model Railroad
Lots of possibilities in the below link.
http://home.cogeco.ca/~rpaisley4/CircuitIndex.html#Automatic
I’ve put in two sets of crossing signals. The first is from Oregon Rail Supply.
These are pretty economical little kits. They do take a bit of soldering, but they built up into very nice models.
These operating gates are from NJ International.
These come fully assembled. To operate the gates, I got a tortoise and some additional components from Circuitron to handle the actuation and mechanical linkage.
I drive both sets of crossings with boards from Rob Paisley (Cogeco.)
Thanks to everone for your help and suggestions.
Really appreciate it
Here are some short videos of the crossing signals, first the Oregon Rail Supply crossbucks and then the NJ International gates.
Well done, Mr. B. I am jealous of your working crossing gates. [:P]
Thanks.
While freight trains dominate real-world railroads and most of our models as well, most of us and most of our visitors first learn about trains as passengers at stations, or as motorists waiting for a train to pass on the other side of crossing gates and flashers. Those parts of a model, therefore, are disproportionately important to stimulating our memories. It’s also one of those things that forms a bridge between a “toy train” and a “model railroad.”
There are times when I just line the turnouts and let one train just loop around the layout, triggering the crossing signals and gates, just to sit and watch them.
