ROAD WAYS FOR TRUCKS
good day to all.
i need some help i am at the stage of laying out the road ways on the FINGAL RAILROAD.what is the with a road in the USA. i would to have two trucks able to pass.
thanks for your help in the past.
PATRICK.
Depends on a couple of things, first are your talking about pick-up trucks or tractor trailers on paved roads ? Most roads in the US are anywhere from 18 to 22 feet in width. Rural dirt roads can be any number of widths depending on where in the US your modeling.
Four lane super highways are 25’ shoulder to tree-line, 18’ to 22’ roadway…to 50’ grass or concrete median, 18’ to 22’ roadway and then 25’ of shoulder to treeline.
Hope this helps…Patrick
Patrick
Beaufort,SC
Dragon River Steel Corp {DRSC}
Whooooops,
Should have asked you what scale are you modeling in,then again it might not matter .
Patrick
THANK YOU FOR INFO DRAGON RIVER STEEL WORKS.
MY MODEL IS IN HO ,AND WILL FEATURE A STEEL DISTRIBUATION CENTRE, FOR PLATE , BAR , AND PIPE.
I WORKED FOR A STEEL COMPANY.
THANKS
PATRICK
I
I am a Civil Engineer in Oklahoma and I occasionally design roadway sections. Typically the minimum roadway width is 26’ (2-13’ Lanes face of curb to centerline.) Local roads are typcially multiples of 15’ outside lanes and 13’ inside lanes. I do not design highways but I believe that they are the same as local roads. I believe that shoulders are typically 12’ wide. Different ares even within the same city will have different needs and they will lead to differeing paving sections.
GOOD EVENING.
THANK YOU FOR THIS INFO,IT IS EXACTLY WHAT I NEEDED.I AM A RETIRED ENG. LIVING 15 MILES NORTH OF DUBLIN IN IRELAND,I WORKED IN THE STEEL INDUSTRY.
THANKS AGAIN.
PATRICK
Well take a break grab a pint of beer and STOP YELLING AT US.
That is to say, turn your “Caps Lock” off. Typing in ALL CAPS is considered as yelling.
Here in Georgia, and in most of the U.S., 2 lane roads are usually 25’ from white stripe to white stripe, with a 12" allowance for 2 yellow stripes in the middle, giving lane widths of 12 feet. 4 lane and Interstate highways generally use the same lane widths.
Brad
