I am a total newbie to model railroading. My grandson and I are building a 4x8 HO layout. Our “benchwork” is 1/2 ply (appropriately framed) below 2" foam board (insulation) - so we can cut out a lake and/or creek or two. On recommendation of our LHS, we are using 1/2 O gauge cork roadbed and flex track. Also on their recommendation we are planning to use matt medium as the “glue” for both the roadbed and track (a variation on the vinyl caulk method). My question: what is the best way to hold the roadbed in place (on foam) on the curves while the “glue” is drying? I plan to use push pins for the track on the curves, but am not sure they are long enough to hold the cork bed, particularly in foam. Trying to be sure we lay our track right the first time. Thanks in advance.
John
John;
The pins should work okay if the cork is not too stiff. If it is stiff, soak it in water, and don’t remove the pins until the cork completely dries out.
I prefer Woodland Scenics foambed. For adhesive, Aleene’s Tacky Glue (crafts section at Wal-Mart) works very well. Matt medium is rather old technology, it works okay, but there are many adhesives that are much superior.
Welcome JSoule
I use HO cork for road bed and attach it to the foam using pres-tite green contact cement (water based latex adhesive). I apply the glue to both surfaces as directed wait for it to dry (20-30 min.) and apply it. Once it is down it will not budge. This is why I mark the foam with a thin line (Centreline) before I apply the glue.
Thanks for your response. I was out looking for some slightly longer push pins (I have few metal ones that are longer) when I smacked my forehead and asked myself, “why not the T-pins I use when building radio control model planes?” Thanks also for the advice on the matt medium. I may give Aleene’s a try.
John
[2c]
I use metal weights. They’re about 3/8" thick, 2" wide and 4" or 5" long and weigh about 4 to 6 ounces. I got them out of the scrap metal bin at work, but you probably find bars of steel at a REAL hardware store. If not check around for metal supply or small machine shops.
For weights, un-opened food and beverage cans and plastic containers work well, and are basically free…
