Robin's rails?
I have this 60’ boxcar and another. got them off ebay and they are from Robin’s rails. it is a clean mold. but the detail set added mostly just ladders is less than impressive. What else can anybody tell me about them?
SHane
Robin’s Rails was one of the fairly early efforts to go beyond the shake the box level of detail on Athearn/Model Die Casting yet still utilize styrene for the material. There were others such as McKeen at about the same time. Similarly outfits like Bev Bel were trying to enhance the paint and lettering schemes on plastic freight car kits.
So where Athearn had most detail molded on, Robins Rails (at least the PS1 boxcar I am familiar with) had separately applied detail, somewhat in the same spirit of the much older Kurtz Kraft plastic kits of the late 1950s which were the real groundbreaking efforts in plastic. The point was that more traditional wood and metal kits had separately applied parts and there was a generation of modelers who rejected plastic for that reason. It took a while to bring those modelers into the fold and accept plastic. It is hard to convey just what a difficult step that was for many older and very talented modelers.
Robins Rails kits were reasonably well thought out but not perfectly designed. If you have built an Intermountain or Red Caboose/IMWX or Pacific HO or original Proto2000 freight car kit you’ll feel right at home with the Robins Rails methods but will need to tinker to gets things to fit as nicely. You will note that the instructions and the kit are both rather vague on the topic of underframe rodding and brake detail.
Most of the separately applied parts that came with a Robins Rails kit are now available as after market parts from other sources (Tichy for example) with much better and finer detail. So you could improve the kit – at a cost, but you might already have a supply of such parts. All I can say is that a “pure” Robins Rails kit, if assembled with care, builds up into a nice enough looking model but any given Kadee PS1 or carefully built Intermountain kit would look better but – again -
To add to what Dave has said, Robins Rails was a company which started up with AHM items such as a PS-2 hopper, either bought from AHM leftovers or directly from the man
Paint it Conrail and you won’t need no stinking running boards!
Sounds like some pieces are missing. No weights in the kit at all. And only a set of ladders. Crude ladders at that. The two I got are 60’ cars. Sounds like I need to get a whole detail package if I decide to build these. Maybe worth putting on the shelf for a later project and look out for detail sets in the mean time.
shane
Robin’s Rails was a spinoff of E&B Valley, which produced a straight-sided two bay covered hopper kit. RR had a fairly decent single-sliding-door 50-footer, a flat kit gondola, and a few other cars. They were current in the early 80s or so.
I believe those kits were supposed to come with weights so it sounds like it went missing. You can always go buy some automotive stick on weights from an auto parts store to add to the inside over the trucks to bring it up to proper weight.
Those kits are crude by todays standards. I have one of the decorated versions. You can look for aftermarket parts if they are not up to your standards.
I have built a number of these kits and modified others, one of their problems is the 60’ car is not tall enough, the person who did the dies measured the top of car dimension to include the roofwalk and should not have but they make a nice car anyway. Also the modeled car uses the short wheelbase frame so the prototype car would fit inside a Plate C diagram due to clearance problems at some Ford plants where the majority of these cars were to be sent to. By making a couple of cuts to the frame and turning the components around you can make the longer wheelbase cars.
Here a few of my cars made from the the Robbins Rails/A-Line/Concor kits.
Here, I modified the wheelbase, removed the rivits as Thrall cars were welded, and changed the doors to match the prototype.
This car I left as is except I removed the roofwalk and used a Walthers cushion coupler pocket on the car and the wheelbase is the stock one as that is what was used on a Wabash car.
D&TS car with the longer wheelbase and Walthers Cushion Coupler pocket.
MP car with the short wheelbase and Details West Cushion Coupler pocket.
NYC car with substitute doors, short wheelbase and Walthers Cushion coupler pockets.
Clinchfield car, with long wheelbase,
Nice work Rick. Time & skill can make a silk purse out of a kit that many of us would put on the “maybe someday” shelf.
Dave Nelson
