I use an Excel spreadsheet on AntiqueLaptop. Excel will sort, accept any amount of text in any cell, and will do selective printing, i.e. print out only selected columns, useful for squeezing the report down to 8.5 by 11 inch paper.
This works for me 'cause I happen to have Excel, and I know how to do neat things in Excel. Presumably Linux has a spreadsheet program competitive with Excel.
If you have access to it, make your own using Excel. I did this years ago with the old Lotus 1-2-3 spreadsheet program, and converted it to Excel, and eventually just rebuilt it.
The thing is, building your own allows you to tailor it to your needs, and of course the program allows you to do limitless sorts. I have copied the spreadsheet for my Lionel postwar, HO rolling stock freight, HO rolling stock passenger, and of course HO Locomotives.
Some of the potential headings could be descriptions, cost, purchase date, car build date, maintenance checks, problems, etc., etc.
For those who would like to use Excel but don’t have it for whatever reason, there is an open-source, free spreadsheet program you can download that’s compatible and comparable to Microsoft Excel. The current version of the program is called “Calc” and it is one of several applications in the “LibreOffice” suite of programs. You can download it for free here: www.libreoffice.org
I have Excel on my new laptop, but on the old laptop I use in the train room, I use LibreOffice, which is not only free but much lighter on RAM usage and disk space (important factors in older machines). Since it’s compatible with MS Office applications, I can do work on my new laptop in Excel, save to a flash drive, then copy it to my old laptop and open/use the file in LibreOffice.
Your original post indicated Windows was an option. Easy Model Railroad Inventory is a windows program, try it on the right platform.
Before you say anything about WINE please reread the download page The important portion of the WINE notice is “It has been posted…” No where does it say it was tested or recommended.
As a retired computer professional (programming/systems) I am happy with Excel. I have one for diesels, including data for maintenance, one for foreign rolling stock, one for ATSF rolling stock. All three are easy to update, keeps my info current. I work between the desktop in my office and two laptops, one for travel and one for the layout on site. Update some car records? update on the layout laptop and then copy the files to the other two using my own network.
Kevinrr, I started an inventory “workbook” on Excel years ago [when I had a few more than 34 cars ] I now have LibreOffice, which, all I had to do was copy the file onto LibreOffice from Excel
as others have said on this thread, using any of the spreadsheet programs makes it so you can customize your headings, sort, etc. I have a sheet for each car type, as well as one for my locomotives. The hardest part for me is inputting the new acquisitions, which seems to be expanding about on a monthly basis. I’m presently WAY behind on that.
I think you are on the right track with JMRI. Getting the rolling stock entered into JMRI is only part of the process. Once cars are entered into JMRI then you are ready for operations. I think this list often overlooks the fact that JMRI is more than a way to program decoders.
BTW, I am not a computer geek, I can barely use one.[swg]
Click on help. Type in Photograph and it will tell you.
A couple of hints. You need to activate the “Draw” toolbar. Do this by selecting view on the main menu. Then select “Toolbars”. Then put a checkmark on “Draw”. Once the Draw toolbar becomes active you will find an icon that inserts picture from file. Click on it and it will let you specify any .jpg file on your hard drive.
I use Easy Model Railroad Inventory, output a report to Excel where I can easily make further changes to suit my need, then send that file to ‘Drop-Box’ which I can access via my smart phone.
