[%-)][8]After many years, I’ve taken my trains out of storage & built an 8x8 table to run them on. My question is???on the transformer what wires do I hook up to what letters???
Thanks
Rob
PS I have a zw transformer
Thanks
Rob
On the ZW, hook one wire from A to the center rail (or 1 on a lockon) and one wire from U to the outer rail(or 2 on a lockon). If you have more than one loop of track, you can use D and U for a second loop. You can also use B and U and C and U, but those connections don’t have whistle or direction controls for them. All the U posts are connected together inside the case, so you can use anyof them you like.
Hope this helps,
J White
[bow][:)]Thank you very much
Rob
WELCOME BACK !!! Great to hear another layout and train will be running in america … [tup] Don’t forget to give them a bit of lube … Here’s a link that may be useful in case you forget :
