I would appreciate any comments, positive or otherwise regarding this track item, based on your operating experience. Is the functionality better than achieving the same result using 4 matched turnouts? The space saved using the 175 does not seem to be substnatial.
I’ve had mine for a couple of years now and am extremly satisfied with it. When you figure using 4 standard turnouts w/o a cross the length is longer, if you add a cross to compress the length the track spacing increase, unless you do a bit of cutting. I’ve had no problem running trains through the dbl. cross at speed. With an engine with close, or a single, pick-up rollers, creeping along. there is a possibility of loosing power crossing the diamond.
