I know it can be done because I moved them on the last layout. But now I can’t find the correct button. I have been through the tutorial questions and all the pull downs (I think so anyhow). but the operator stays put.
THANKS
Ellis[:-^]
THANKS
Ellis[:-^]
What’s the question?
the operator for either left or right hand 022 postwar switch operators can be mounted onthe opposite side from that originally supplied . i am using “RR-TRACK V4.02” To make a layout plan But don’t remember what key stroke to use. If you know please let me know.
By the way this igreat progeam.
Thanks Ellis
Ellis,
The following should swap the switch motor/lamp from one side of the switch to the other on RR-Track ver. 4.02.
Thanks Chris that is just what I’ve been looking for.DO YOU LIKE THIS PROGRAM Ithink it is the brst.
Thanks
Ellis
Ellis,
Glad you were able to get it to work.
I like the program a lot, but it does have some quirks that took some time to get used to. I still don’t have the hang of the “join errors” and which is the best setting. Overall it has been an enormous help. I love having the ability to add buildings and landscape and then view it in 3D.
Chris
