Rrebell's layout, new pics added
Been workining on this build and ran a thread earlier about best adhesive for the metal siding. Went with contact cement and also found out doing two coats on the cardboard worked better along with the best way to cut it into panels (a Chopper with two or more layers and a fresh mat) and best way to cut trim (very sharp scissors). Now I am at the folding over the paneling at the corners, holds on its own but I wanted it to sit flatter so ACC it. Worked great. Next up is paint and the question is should I just go with a rattle can light grey matt as a primer coat or a flat matt spray and then the rattle can or ? Final finish is up in the air as I have rusting powders and mediums and I did a small shed roof in metal and it came out great by drybrushing varius browns and red browns.
I’d just go with the rattle can gray primer. That’s going to be the underlying color anyway.
Hello All,
Great progress on your build.
I would recommend Rust-Oleum Painters Touch 2x Ultra Cover Primer Spray- -Gray.
This adheres to many different surfaces- -wood, plastic, metal, and more (according to their information.)
Keep in mind most primers, no matter the color, are intended to fill in the gaps of rough surfaces to provide a smooth surface for the “priming” of the final finish coat(s).
Several light coats, to maintain the details, are advised over one thick coat.
Also, use the Bane Marie method to heat the can to make the paint flow easier.
Put the can(s) in a container and fill with hot tap water- -do not use boiling water!
Allow the can(s) to soak, shaking frequently, until they are warm.
Depending on where you store your paints you might need to refresh the water once or twice.
Allow each light coat to dry thoroughly before applying the next coat. This will help maintain the details.
Again, great to hear of your progress, keep us updated and as always…
Hope this helps.
Tested that paint, way too thick. Not all primers are thick.
Hello All,
In painting preparation terms, a “primer” is intended to be thick.
Unfortunately- -for us modelers- -these typical "primers" mask the details we seek to preserve.
A “Base Coat” can be applied as a stand-alone coat to enhance the final finish or, after “priming” the surface to be painted.
Base coats are not thick.
They are not intended to fill in the irregularities of a surface, or- -for us modelers- -details.
Light colors: white, yellow, and some tints (lighter colors) of blues and greens can benefit from a gray base coat.
Darker colors benefit most from a brick-red base coat.
Sounds like you might not need to “prime” the building for painting.
Just paint the structure the base coat color of your choice and, weather accordingly.
Hope this helps.
If you really want to use a spray can, Tamiya seems like a good suggestion, but I have never tried it on metal.
-Kevin
It will be rusted corrigated siding. Instructions are hard to follow but the drawings are great. Got most of it built now but since I am staining the wood parts and heavily weathering the rest it is still in sub assemblys.
Still working on the project, found a few things were wrong in the instructions, not unusual for a lot of craftsman kits, opening for the tunnel tipple was wrong size and a few other minor flaws having to do with the card parts just being wrong but all is fixed. Worst part is redoing the base area for the mine, guess my mock up was not right, guess pen widths add up.
I left the metal natural and weathered it. I used Acrylic Oak stain on the wood then added a bit of weathering.
Mel
My Model Railroad
Bakersfield, California
Turned 84 in July, aging is definitely not for wimps.
Ya, I saw your build thread, wish I could post pics but after the last disaster with pic hosting I said to myself, why bother. Other forum that used to exist I posted pics all the time from my computer direct, they limited the pixels so no storage problems. Mine I went with an alcohol stain I have been using for years. For the metal I usually go with a rusting solution but think I will go with a drybrush job, metal already primed with light grey.
Do those lights on the headframe work?
Yes, there are a total of 13 2mm 12 volt incandescent bulbs on my mine. I operate all my structure lighting at 70% to increase lamp life and operating at 8½ volts they look much more realistic for the 1950s. The lamp shades are dimpled 2mm washers.
The elevator winch cable is automated, it moves back and forth turning the pulleys, controlled by an Arduino.
Mel
My Model Railroad
Well I wish I could post pics but the mine is done and I was able to make it removable, even with the cable and all legs attatched, overall it turned out nice with rusted corigated windows stained to match the stained woodwork.
Send me your pictures and I’ll post them for you. My email is in my profile.
Mel
My Model Railroad
Thanks I will proubly do it monday so daughter is around if I have an issue with sending.
Hey Mel, sent pic of mine as well of whole layout, PM did not work last time I tried.
Helping out rrebell.
Mel
My Model Railroad
That’s a good-looking layout rrebell. And thanks to you, Mel, on helping out to allow the rest of us to see it.
Thank you again Mel.
Sure is. Thanks for sharing!
