I have a problem trying to get this Atlas freeware to work. I have been following the tutorial and get to the part that says to “select the 90 deg crossing”. It is supposed to be in the icons above the grid but it isn’t there. They also suggest to get it from the library under the “elements” heading. It’s not there either. I just downloaded it yesterday so I presume all updates are current. Any suggestions?
Bruce,
I just checked my version of RTS and I have v. 7.0.2.33. I clicked on the update button but was told that it was the most current version.
The 90-degree crossing is 4th from the far right in the icon row.
One, check the load libraries option on the elements drop down menu to make sure you are using the desired track lebrary.
Two, check the configure library option on the sa,e drop down menu to insure that the 90 degree crossing is NOT on the don’t use list
Have fun
