Rule of Thumb
Hey Guys,
I need a rule of thumb for figuring the effective grade on a curve that has a known actual grade. I’m thinking of designing a helix and need to know how to estimate the effective grade.
Even tho I live in a sandfield, I don’t want to use all that sand in my engines[:p]
Thanks -------- John T.
http://www.fortunecity.com/westwood/beautiful/819/HeliCal.htm
This might help. If you do a search for helix on the forum you’ll find tons of stuff.
Thanks loathar!!!
On the prototype, according to the army corps of engineering, a one degree curve is equivalent (in resistance) to 0.04% grade.
So recalling that a degree of curve on the prototype is based on a 100 foot cord.
The radius (in feet) = 5729 / degree of curve
A 22" radius curve in HO = 159.5 scale foot radius = 35.9 degree curve
So 35.9 degrees times 0.04% grade/degree = 1.4% effective increase in the grade.
However - I seriously doubt the physics of a toy train drag through a curve are the same as that of the prototype.
My ARA track engineering guide mentions .05% for each degree of curvature. But my tables show that a 22" radius HO curve is about 40 degrees(actually just a little less). The NMRA web site also lists a 22 " radius HO curve at about 40 degrees…
Jim Bernier
