I have a three months old Athearn FP7 w/Tsunami Soundtraxx. Itbhas been running great. I did change the number address to a 4 digit number and adjust CV3 & 4. Everything has been great.
Today the locomotive started moving on it’s on as if someone else was controlling it. It would even ring the bell, blow the horn, and reverse on it’s own.
I put it on the program track and tried to reprogram everything - to no avail.
All of my other engines are operating fine but, this is the only Athearn I have.
Di you have any additional throttles besides the Zephyr console? You may have that address selected and set with the bell on and a non-zero speed. Unless you have a bunch of consists created, look in the back of the Zephyr manual on the Option Switch settings and close OpSw 36 to clear the memory on the Zephyr and see if the problem goes away.
I am in Savannah on business and not near my layout (near Atlanta). I do utilize a UT4R remote Throttle. The locomotive I am having the problem with is the same selected on the throttle. I think you may have hit on a fix. I’ll try it when I get back home.
