Running a DCC Equipped Loco in DC
All this make’s me want to know. What is the advantage or maybe what is the pupose of disableing analog mode?
Is there any problem running them with analog mode inabled?
Larry
I’m not sure of the exact technical explanation, but as I understand it there is a DC component to the DCC signal (or something that looks like DC to the decoder). And when the track (or the loco) is first fired up, that DC component gets to the loco first. And when this happens the decoder thinks it is seeing DC and the unit will run away out of control. I don’t know if this is a problem with the current breed of decoders, but it used to be a problem with earlier decoders. Anyway, to prevent this from happening, the advice was to disable the analog mode.
I’m sure someone can chime in with a more correct technical explanation if I have any of the details wrong.
If the track power comes up before a stable signal is generated from the command station, a decoder set to allow analog conversion MIGHT see that as DC, and all that really does in the decoder is turn on the motor drivers, so the track power goes right to the motor, minus a little bit for the drop inside the driver electronics. In such a situation, the loco can suddenly take off in one direction or another.
The below link might shed some light.
http://www.wiringfordcc.com/runaway.htm
Be advised, a motor never sees direct track voltage from a decoder. The motor sees what the micro processor sends to it via the motor drivers. Either positive or negative going pulses, PWM. The track voltage goes right to the micro processor first. If the processor gets confused, it might not pick out the correct program from the ROM on the decoder.
The track voltage also goes to the bridge rectifier to develop the DC voltage operate the decoder.
What is the advantage of disabling DC in a dual mode decorder?
Read though some of the responses. It has been mentioned.
If you sell your DCC loco to a DC guy, he will NOT be able to change it back himself, because he has no DCC gear that will do this for him. Well, ok, I can do it: I open up the loco, remove the offending electronics and wire it my way.
If it’s a plug-in decoder or you otherwise didn;t cut wires or modify it, you can sell the decoder too. Probably get more by sellign them seperately as well. On the other hand, plenty of people would like a loco they can just take out of the box and put on the track, without having to install a decoder.
