Chris “Birds” sent me this by e-mail. I am answering him here because this topic seems to be generating a lot of interest lately.
"I was reading your comments on the CTT forum about trains running across blocks set to different voltages. I am trying to understand this and have some questions if you don’t mind.
"I have read through both volumes of Peter Riddle’s “Wiring Your Lionel Layout” but don’t recall this being covered.
"As an example:
"I am running a KW transformer.
"I have a loop of track (Block A), and one turnout off that loop.
"This turnout leads to a very long siding (Block B) isolated from the turnout with a fiber pin on the middle rail.
"Block A comes off post A of the KW.
"Block B comes off post B of the KW with the intent of allowing the engine speed to be slowed down and controlled separately as it crosses into this block.
"If I understand what you are saying, you do not recommend this setup because at some point an engine or lit car can straddle both blocks A & B, and if the voltage between the two blocks is set differently, then this could short at the winding coil, and is a possible fire hazard.
"My confusion comes because in the owner’s manual for Lionel’s new ZW there is an example of single throttle train control for a simple loop using different blocks set to different voltages to maintain a constant speed over grades.
"Would this setup have the same concerns as my setup with the KW, or is there a difference between vintage KW and ZW transformers and the new ZW in this regard?
“What would you recommend doing to protect the transformer in this case if I wanted to have separate throttle control?”
Enquiring minds will want to look at the wiring diagram for the KW on Olsen’s web site: http://pictures.olsenstoy.com/cd/transfmr/pskw2.pdf There you can see that, except for the whistle and reversing switches in series, terminal A
