Hello All,
The term “bus” has been borrowed from the early days of the computer industry.
It is alive and well with the USB- -Universal Serial Bus, which can be used with all computers with these connectors.
Originally it referred to a “bus route”, where the “bus” would travel a specific “route” and pick up passengers and drop them off at various points along the continuous route.
The way this translates to computers is the “main ‘bus’” is the electrical path that the computer’s components are tied to- -disk drive, CPU, and other peripherals.
Signal packets travel this “route” and get on and off depending on their “destinations”.
For DCC it’s really not a complete circular or connected “route” it’s more of an out and back.
DCC manufacturers don’t recommend connecting the ends.
Because the rails of model track are not the best conductors of data, with the advent of DCC it has been recommended to run a set of wires underneath the track and tap into this “bus” at every other track section.
With sectional track that is a lot of feeders per 9-inch section. With uncut sections of flex track it’s about every 6-feet.
To answer your question…
Run an additional set of bus feeders; of the same gauge wire, under the crossover section.
This will create a “Y” section of the bus under the crossover section.
Do not tie these into the bus on the other side of the crossover section.
Also, do not make the bus a continuous loop- -connected at the ends.
The command station/booster should be placed approximately equal distance from each end of the bus wires.
Connect the bus via feeders to the track.
You did not mention the length of track you are considering.
Take a look at this thread for further discussion of signal and power strength over long distances.
